I'm really enjoying playing around with the OR solver. One aspect (among several others I'm afraid!) that I have not got to grips with is using composite shells. If any one can point me in the right direction here I'd be very pleased. I think it will required some form of custom model definition to change the shell property definition to some form of composite shell definition like /PROP/TYPE9 (SH_ORTH). When i try and run the attached file i get the following error
ERROR ID : 1052
** ERROR IN PROPERTY SET
DESCRIPTION :
-- PROPERTY ID: 1
-- PROPERTY TITLE: Default shell
-- MATERIAL ID: 1
ISOTROPIC SHELL USING ORTHOTROPIC LAW
.. ELEMENT BUFFER INITIALIZATION
ERROR ID : 3047
** ERROR IN MATERIAL/PROPERTY COMPATIBILITY
.. GEOMETRY PLOT FILE
In the input file generated for this simple example I see the following lines of text - I was hoping to some how use this block and redefine as a SH_ORTH
/PART/1
Default shell
1 1
/PROP/SHELL/1
Default shell
24 2 2
5 0.007 1 1
/SHELL/1
1 9 21 25 11
2 21 6 23 25
3 25 23 3 24
4 11 25 24 7
5 8 10 14 13
6 10
