I am able to use the thermal conductance contact model w/ the CCX solver so far so good, provided hex elements are used. The interface contact constraints appear to be refined when the component meshes are refined. I now need to extend analysis from rectangular components to curved components. Haven't found approach that works with tet elements. Suggestions?
To do this with existing loads, select the surface(s) in the geometry view, then right click on the load -> Edit and you should see an option in the dropdown for <1 geometry surface>.
Or create new loads that way by right clicking on the surface in the geometry view.
If you're using Mesh tools -> Automesh 3D then that does lose boundary conditions and it's not recommended compared to a STEP file.
If I'm still misunderstanding, perhaps you could post a .liml file or screenshot.
I think contact as you're doing it is probably the best approach. An alternative is to model the interface as a layer of solid elements. Maybe formed using Mesh tools -> Extrude to avoid contact but it might get complicated depending on your geometry.
