Hi Everybody,
My project is rather simple but 4 spring segments (most distant from the center) do not take part in the forced displacement .I discovered this after v28 installation.After returning to v25 (version the project file was prepaired) problem remains.Similar spring containing 8 segment lines works OK (problematic spring contains 9 lines).Any help?.Project file and animated image is attached.
Regards Wjasiew
There is a line element in between the model too.
You can find it with the tool Select elements by ----> and then Line 2 Line 3. Then erase it.
What a cool shape.
Your model looks difficult to me. Your spring is thin and has significant presence of Shear Mode III .
Going the other way, something weird happens if you try and convert all elements to linear. Not only the "hex8...deprecated" warning, but the results differ from full 2nd order case by 1/100.
EDIT: When the model was flattened to shells and cleaned up, linear analysis behaved as expected and took just a couple extra resolution increases to equate with quadratic. Extruding the shells back into hexes, still got the "hex8" error. Dunno. Maybe the linear wedges are causing that??
I was surprised that the 9-line model was partially (9th line) out of order while the 8-line model is simulated quite correctly (both animations included). The structures of both models are identical.Is the mixture of hex8 and hex20 really the reason of this selective fault?It is rather hard to believe for me.
Thank you all for your kind activity.
