I'm working on converting liml to Caclulix inp. In Mecway I assign a heat flux to a surface. This is converted to a CFLUX in the Caclulix file, which is based on the nodes.
How are the nodes weighted for the Caclulix heat flow rate?
Frank
i is the node.
N_i is the face's shape function for node i.
phi is the heat flux you specified.
If more than one face shares a node, Mecway sums the heat flow rate contributed by each face to give a single value per node to *CLOAD.
