Victor, I would like to ask if there would be a possibility to have beam end releases for the 3 translations and 3 rotations at each beam element ends. Currently, we have the "New Flexible Joint on Beams" feature that gives release option to the 3 rotations for both ends but not at each end and no translations release option. Thanks
You can release rotations at just one end by applying it to one end face of the beam element. That's sometimes a bit tricky to select. Either:
A) Select the end node then switch to face select mode or
For translations, can you give some details of your use case? For now, you can do it using constraint equations, but you have to do some trigonometry to define the equations so it's not very handy.
