Hi all,
I'm experimenting with gmsh and the types of mesh output I'm getting. I like how surface only gives a nice structured mesh, but volume doesn't. So I wanted to change gmsh setting a little to experiment.
When I put anything into the custom command box the mesh fails.
Remove it, meshes perfect. I'm 100% certain it's something I'm doing, but is there an example somewhere or something to show how it works?
I've done a typical Google search and there's the odd thing on this forum, but I want to try and understand the different mesh types and trying to call them up.
Thanks in advance
I dare say there is more to it which I'm yet to discover.
So some of the mesh options go 0=default 1=delauney 4=frontal, so my immediate wondering was where are 2 and 3, or what are 2 and 3.
https://gmsh.info/dev/doc/texinfo/gmsh.pdf
Prepomax has implement most of Gmsh commands in a really amazing way. It is even more friendly than the Gmsh GUI itself.
It seems to need an end command which I need to try and understand as well, I'll check out that manual
