I frequently use thermal expansion of truss elements in my yacht rig models to vary tension of rigging elements. Generaly this presents no problems but some times when I'm looking for large changes in length of an element (over 100% or more) I run into convergences issues. Is there a limit on how big a change in length one can make? I have attached a simple model were I was investigating these thermal expansion affects on a single truss element and was interested to see that when I trying to double its length by thermal expansion the the analysis did not complete -can anyone help explain why? When I applied a small axial tensile force the operation completer
Although that's usually physically unrealistic, in this case, the mechanical strain is near zero so I'd say it should be a reasonable approach.
Models with no load like this sometimes don't converge. But that seems to be separate from the problem of using this in an actual loaded structure.
Be careful with *PRE-TENSION SECTION because it doesn't update its orientation for large rotations. It looks like you can see that happening in your mpeg where two elements move out of collinearity but remain parallel.
@Victor. Right. Large Strains require other strain framework to get realistic results. Hyperelastic unfortunately has the default compressibility bug that has been reported when model is set up in SI units.
