Hi There Since upgrade to 25th Version. Unable to run this simple (only orthogonal plates) model for plastic analysis. Could someone check what i am doing wrong.
It didn't finish solving in either 24 or 25 for me. It's possible you have a different version or build of CCX used by 24. 25 would have defaulted to the built-in one when it was installed.
I tried running without plastic properties, still does not complete. I would check your set up with a linear run before you add plasticity. Also, bilinear curves are usually 1/10th the elastic modulus in the plastic region ~ 21MPa for your steel. You are currently using 1MPa - this is too soft and also difficult to converge.
It solved with the dent in the larger plate flattened out (set to y=0). I wonder if there's buckling happening around there leading to poor/no convergence. Is this something you're expecting or want to capture?
With the dent in place, it solved a little bit (0.00099 s) with very small loads (0.001 s initial time step and t^2 load scaling factors). Perhaps that's about the critical load?
Many thanks Victor for your runs. I was getting first conversion and then nothing which suggests buckling at that small load as you got. I was expecting buckling may be not that earlier, however, there seems to be an issue with the plate. Many Thanks much appreciated.
