it's probably a ccx expanded shell model. if so, you have to use the output=2d option to output the midplane. the issue there is the stress won't be correct. so ignore any stress when using output=2d.
That's usually what causes it, but in this case, it's an unused node (876). Nodes without elements don't go through to the solution in CCX so delete it before solving.
Victor, if I have a node-to-surface coupling with a "floating" node, is there a better way than deleting the node, transferring and remaking the node-to-surface coupling?
