*ERROR in nonlingeo: max. # of increments reached
mdsimulationgroup
June 2024
I run the attached input and it fails around the 20s mark regardless of the timestepping with the error in the title. Anyone got any ideas?
Frank
Rotation.liml
14.5M
mdsimulationgroup
June 2024
I have found that if I change the modulus to 1Pa, the solver will go longer...up to around 120s before failing with the same error.
June 2024
CCX sometimes fails such large rotations at specific angles. You can work around it by altering the time step from 2 s to say 2.1 s and it seems to avoid whatever problem it got stuck on.
