Make hex20 faster
Is there an easy way to generate a hex20 cube, similar to the "Quick Cube" command?
Thanks!
Frank
  • Generate a "Quick Cube". With the cube element still selected, hit the "Change Element Shape" button, chose "Linear->Quadratic" (if not already selected) and hit the OK button. The number of nodes should have changed from 8 to 20 and if you use the "Select Nodes" button you should see all 20.
    Ken
