Easy one for the Mecway Team
For some reason I can not reply to Johns post so I have had to make a new discussion - anyway I have attached a possible solutions to his problem -I'm not sure the sign of the solution is what is required. Interestingly I had some odd results with the displacement once I had suppressed the force component so had to reduced the time of the steps
src="https://mecway.com/forum/uploads/editor/9h/uak3qf6msbbb.jpg" alt="" />
  • Thanks for looking at this @fatmac!
  • FYI, here is what I am currently do that works but is a pain to implement:
    -I set the modulus of the component of interest very high and re-run.
    -I dump displacements for the "real" and "stiff" cases.
    -I take the difference between these cases and create a big *BOUNDARY input file
    -I use those displacements to run a dummy Mecway run
    -The deflections show the flex displacements without the rigid body.
    Pain in the neck!
