location dependant force
Can anyone suggest how I can vary force with location -I was hoping to apply a horizontal gravitational force that was a function of ght -something along the lines of z*A, but I have not been able to find a method of doing this. Probably some form of custom card may work out. One other approach may be to apply a pressure that varies with location - not quite as useful for me but if I could do that I may be able to use that type oy solution Any ideas or pointers would be most welcome.
  • edited March 2024
    For pressure against a vertical wall between, say, z=0 and z=40, you might simulate a linear hydrostatic type function by multiplying peak pressure * height ratio. Pressure = [Peak*(z-40)/40]. Adjust vector sign (+/-) as needed.
    If you try to duplicate this using Traction on an inclined surface [angle (A)], you'll need to also be mindful of the appropriate cos(A) and sin(A) cofactors.
    Also, maybe these prior posts?:
    https://mecway.com/forum/discussion/847/how-to-define-the-load-that-is-variable-along-the-perimeter/p1
    https://mecway.com/forum/discussion/comment/5676#Comment_5676
  • Another idea is to vary the density rather than g. With CCX, you can define density as a function of temperature (just make it a linear function using 2 density/temperature pairs), and apply a non-uniform temperature field (defined by formula) on the whole mesh.
    If you have a structured mesh, you could use pressure or traction loads like cwharpe suggested but also on interior faces. Use the cutting plane to expose interior faces for selection.
    If it's nearly 2D, you could use centrifugal force which is proportional to radius.
  • thanks guys - that has
    given me some great ideas. I've started playing with the variation of density with temperatures. I see that temperature allows a location dependency, so I vary this with a function based on hgt (z). I then apply a custom step card with a *density that varies with temp -as shown in the attached pic. Then I add a gravitational acceleration in the direction I require. At that point I have got a little lost! I think my first error was trying to work in deg c, I now think perhaps the custom CXX cards are in kelvin so I'm trying to get my head around that. The final hurdle is to actually know what equivalent accelerations I'm applying where. Any hints are welcome. I have tried to get a handle on it by applying the process to a unit vol. at a given hgt and then working out the force on that -I'm slowly getting there but any additional help would be much appreciated.
    thanks in advance
  • edited March 2024
    That look pretty much right.
    To keep it simple, I would eliminate scaling for everything except one value like this:
    Thermal tress reference temperature = 0 K
    Density = temperature, like (-1e9,-1e9) and (1e9, 1e9) instead of (0,0) and (500, 373). Use a huge values to ensure you never exceed that range.
    Gravity's g = 1 m/s^2
    Then the position dependent temperature in K is equal to the signed magnitude (if that makes sense) of acceleration in m/s^2 so this is the only part you need to tune to your specific problem.
