Feature: number of copies
I think that could be useful to set a numebr of copies on move/copy window. For example I have to repeat 73 times the shell elements selected on attached screenshot.
To do that I have to create a single big element and divide it by refine...or the is a faster way? (excluding counting number of clicks on copy window)
  • Agree there could be some refinement for the Move/Copy tool, but for your case shown:
    Is an extrusion of the end-faces possible? A total thickness (distance), with 73 subdivisions (new elements).
  • I think that "extrude" command generates degenerated elements
  • Oh!.
    ¿Do you have available any case where extrusion degenerate the elements?
  • For extruding such elements you must select the "border" and not the faces.
  • With border runs
  • #copies would be a good addition, in the mean time, I do 2 things:
    1 - extrude the edge, as others have said or
    2 - make 10 copies, then make 7 copies of my "10copy set". at least there's lot less clicking!
    extrusion example:
  • I didn't think about "extrude"...maybe because after many years using CAD softwares minds about copy option. Same consideration for copy one or more element from one node to another: select-> click start node -> click end node could be useful.
