Compression Only Gap Clearance
Is there some way I could add to the Compression Only Support some gap clearance on the GAP elements?
Thank you.
  • No easy way, sorry. You'd have to write the *GAP card yourself which would mean including all the stiffnesses yourself too. Maybe let it generate them without the clearance, then copy and paste into custom model definition with the clearances inserted.
  • Ok, I will try.
    Thank you.
