Hi guys I've been trying to model a rope running around a sheave. I've struggled with trying to model rope before, I'm trying to produce an element that has tensile stiffness but no bending stiffness, I've looked at a series of short beams, trusses and solids and not really come up with any nice solution. My best approach so far is to use a thin 'belt' so the stiffness in one plane is small. I'd like to progress the series of beams or trusses but run into contact issues with the trusses and don't have simple approach to connect the series of beams with no stiffness at each junction. I've added 2 samples of my rather poor efforts so far. Any ideas would be welcome
Contact problems between curved surfaces require a good initial node position.
I would recommend you to start with finer mesh on the belt and use the project nodes into cylinder tool to adjust the positions to a common circle.
Remove any non-useful element to speed up the analysis.
Use reduced integration as it is less stiff.
Define a maximum time step to help the convergence. Start with 1mm not 50mm to check contact works.
Swap Master and Slave. Slave shouldn’t be the largest and coarser surface.
Look at the deformed shape if it fails. Will tell you what is going wrong.
It's a Mecway meshing tool (Project onto surface). The idea is to prepare both surface's nodes accurately following a desired shape. You have available a cylinder similar with your scenario.
Your contact stiffness seems too small. There is some penetration of the belt inside the Sheave, but the contact seems more clear now.
I can see one issue with this set up. Unless you are interested in the first engaging of the rope on the sheave, your spring is increasing the tension linearly. I guess a loom is supposed to be working with constant tension.
Not really sorry. The material definition and parameters for rope is completely unknown to me.
