Hello!
I need to run some numbers on how hot one of my connectors is going to get. I still need to do some research before setting up the models but higher level question: is this actually possible in Mecway? If not are they are other F/OSS ways to do it?
Thanks!
If it's fairly uniform, you could manually apply internal heat generation using the solution values read from the DC solution.
Would this qualify as a multiphysics problem? Trying to find ways to get a solution and just want to know what I should be looking out for.
Time to RTFM!
