I am new to using Mecway and although I have past experience of FEA it has been nearly 15years since I used any software (past experience was Abacus).
I am trying to do some simple examples to ease myself into using the software and have set up a very simple static 2D 'beam' problem however although there don't seem to be any input errors, I get a 'Invalid stiffness for element' error and would grateful for any suggestions as to what might be causing this.
My project file is attached.
Many thanks
Bob
I think your issue is the plane you are running in- I rotated into the XY plane for 2D and it seems to run fine.
thank you for the link to other resources and also for solving my problem :-) I'll now know to consider the orientation if I'm using 2D.
Thanks again
Bob
Also the deformation is a little bit high, maybe you should do a geometric no lineal analysis.
thank you very much for the advice. I'll have a look at both options, further useful exercises to enable me understand the capabilities and differences to be found in the software.
Thanks again
Bob
In CCX, shell elements are expanded into hex8 with c3d8i shape function
We usually use hex8 with the CCX option to use c3d8i option (see CCX in tree)
hex8 c3d8 are too stiff in bending
hex20 c3d20R are supposed to be a very good option, but we usually use c3d8i
