Looking at modeling a stair superstructure with CCX Rect. Tube cross-sections, with intent on running NL analysis. Just trying out Static3D with fixed-end constraints for simplicity.
I can get the solver to run for (Line3) beams in most positions EXCEPT for beam slopes between ~42 deg. and 90 deg., wherein I am met with the "ERROR in cascade:..." solver fail message. (I advanced the SlopeBox beam group by z-axis rotation about zero.)
Anyone see this before? ~Thanks.
There seems to be some conflict with the application of shared BC for arbitrary beam orientations.
It could be solved adding a common orientation which is always recommended for beams.
Still mis-behaves if the beams are separated apart. Also, each beams' V-axis seems correct in the orthogonal position to the beam axis? It is puzzling why some angles work, others don't.
If "a" dimension is very close to "1.5b" it fails.
This doesn't happen if you switch a by b.
a=149mm
b=100mm works
a=150mm
b=100mm fails
a=298mm
b=200mm works
a=300mm
b=200mm fails
I guess if with those dimensions some nodes end up with the same coordinates after expansion.
@disla: Well, you are on to something. Turns out CCX will pass solver for all principal angles in the plane up to the limit of arcsin(b/a). For b/a=100/150 yields my 42 degrees (41.81..). Just an eyelash past that angle CCX solver fails. That seems to describe the behavior, but I just don't know why.
@Victor: Any insight into this riddle with Rectangles? For squares, arcsin(b/a)=90 deg., so no problem with any beam slope.
I did find a workaround is to *TRANSFORM the constrained node so the node's axes align with the beam's, then it seems to work OK.
@cwharpe, interesting observation about arcsin(b/a). No idea what it might imply though.
@Victor: I was able to get the *TRANSFORM card to work, so Thank You for that. No free lunch, however. I had to keep working the trig to load it properly, then to interpret the results from Beam coord. system back into World C.S. -- became a little twisted for me to compare apples to apples (CCX vs. Internal).
There is a "trick" that seems to work-out OK. When the beam slope is beyond the sweet spot of arcsin(b/a), I found that adding a micro "dog-leg" to each beam-end permitted the model to solve. That is, tiny beams are created by extruding the end-points horizontally (or vertically) by a fractional amount such that the new end-pt. constraints can align with World C.S. The small error this introduces to Solution is proportional to the length of the dog-leg offset. For my level of precision I was finding b/1000, maybe b/10000 to be acceptable. Naturally, a poison-pill to this setup is forgetfully Merging Nodes.
Thanks to all for the help.
