I'm comparing 3 models of a I beam under torsion, one with just 1D beam elements, the second with 2D shell elements and the last one with solid elements.
The model with beam elements gives a maximum rotation angle of 14º, but the other models give maximum rotation angle of 9º.
Manual calculations give me almost 14º, but I'm not sure if I did it wright (I'm just a chemist, not mechanic engineer).
I couldn't find errors in loads and restrictions so I can't explain the difference.
I'm attaching the models file.
PS: There is no difference in the behavior of the 3 models when bending.
The torsion constants for beams assume they're free to warp regardless of the constraints, which is perhaps misleading.
I´ve also seen that there are several formulas for the torsion constant for this profile, so manual calculations may be between 9 and 14 degrees depending of the formula used.
I put something like a fixed diaphragm constraint (Y and Z constraints on the whole surface, and X constraint on one node for rigid body motion) on the shells and solids and now all 3 agree:
14.9 degree solids
14.9 degree shells
14.5 degree beams
Mecway shows the torsion constant that it uses for beams in the material properties box. It's using a formula from Roark's Formulas For Stress And Strain.
Roark's formula is an aproximate value.
It for this I section (r=0) is It=47.963 cm4
Introducing that value on a general beam section produces the exact result of 14.56º which agree with the analytical solution
