Surface mesh with poor element (nearly colinear nodes)
The attached model generates the following surface mesh for quad dominant elements. Note the element in the upper left which has nearly colinear nodes along the curved boundary of the model. The same mesh results with either the internal mesher or Netgen 6. The meshers could correct this by specifying a maximum included angle between adjacent sides (e.g., all included angles less than 135 degrees). If such a quad element isn't possible at that location then it should be split into two triangular elements. (Of course I could manually adjust the meshing parameters to correct this problem but this shouldn't be necessary.)
