Two nodes coupled deformation
Is it possible to set coupled deformation for two nodes in Mecway? Let's say that I want two nodes to move in z direction for the same value. But this value is not set, it just depends on the structure deformation and in post processor it will be the same.
I think, that in Ansys, I could do that, but here I can't find it or it is non existent.
  • Look at Loads & Constraints ---> New Constraint equation
  • JRPJRP
    edited November 2022
    Thanks disla, for this heads-up. But this constraint equation is not available when I right click on a node and select Loads & Constraints - it is greyed out. I have to right click on Loads & Constraints in the tree and then I get the option to set it.
  • I have to right click on Loads & Constraints in the tree and then I get the option to set it.
    Right. It works that way. Take note of the nodes number first.
  • Yes, I did that. I already used it in a buckling analysis. It worked as predicted...
