Advice on mesh definition
Please refer to the attached file.
I’m trying to model a concrete bridge deck with pipes inside. The problem is that pipes should start from each side. For the first 7 elements, the deck should be solid.
Is there any way to modify the mesh?
  • Yep,
    -Select all the holes inside surface with the edge detecting tool.
    -Extrude to the inside direction (normal) to create the solid pipe. Recommended three elements per thickness
    -Inmediately create a new component.
    -Hide all but the new component and erase the length you don’t need.
  • edited November 2022
    In case you need solid fill of concrete in the middle, here's an extra trick you might need:
  • Thanks for your reply but unfortunately I can't work it out.
    I should create a solid cylinder over the first 7 elements rather than an inner pipe.
    By using the JohnM's trick, how can I get a solid 3D element?
  • use the extrude command in mesh tools. you can extrude with a thickness and layers that will match your existing concrete.
  • I've tried but I get conpenetration of elements that I can't improve.
  • @andreac91 see attached using method above. You should be able to delete any number of layers to achieve your desired result.
