Dear Madam/Sir,
Is it possible to add continue from one analsysis to another option? In example, I am a civil engineer and I analyze structures with first gravity loads (linear-nonlinear static) than after that load, transient dynamic (linear-nonlinear) for earthquake loads. Also, is it possible to add combination support? In example my structure is loaded with wind loads and I want to add live loads or dead loads (gravity). This should be with factors, in example, 1.4 Dead + 1.2 Live
You can combine loads in different combinations by using a separate configuration for each case. Suppress the unwanted loads in each configuration.
You can write the factors directly into the loads using multiplication symbol (*) but there are no variables to apply the same factor to multiple loads.
