I’m receiving an error in Nonlinear analysis but I’m not sure why.
*ERROR in forcadd: it is not allowed to define two concentrated loads/fluxes different amplitudes in one step node: 2 dof: 1
My loads are entered as a table, and I have tried to apply the loads sequentially, simultaneously and in one and two separate loads. ¿Is there any workaround to solve this?.
I do not remember to experiene this limitation before. I’m trying to check why is this not working using one of my old files but it doesn’t work now with v16.
The file was posted on
https://mecway.com/forum/discussion/1102/radial-stiffness-of-precalibrated-bushings-woehler-curve-w-n-curve.
PreCalibrated Bushings REV1.liml
Could you please post the .liml and .inp files?
A workaround is to change the two forces on the shell edges to be on the nodes instead. It should be pretty close to the same thing since these are linear elements. Then it does solve.
