Could you clarify where the problems happen? I don't see any duplicated elements nor the beams merged to the solids or shells when I apply Refine custom to the whole model or to just the shells.
Running the model just opened the plates separate as they are not attached in any means. After a Custom refinement 2,2,1, the nodes between plates are merged and the solution gives cero displacement .
Additionally, internal solver shows a warning.:
Warning: Elements 65, 74-128 ... are duplicates. Use Tools -> Find duplicate elements to show them. .
I think I see what happens. You fixed the custom refinement adding a merge operation as some of the middle nodes disconnect in previous versions. Now , when merging, there is this particular case when two elements that are going to be refined overlap and end up merged together.
Maybe a warning before proceeding if some of the nodes thar are going to be Custom refined are overlapping?¿?. Or maybe proceed as Refine x2. Curiously it doesn't show this problem.
Oh, I see now. I was somehow looking at the wrong file before. Your explanation does sound like what happened. I'll see about adding a warning in a future version. Fixing it properly will be more difficult than Refine x2 because it has to keep track of more in-between nodes.
