1D (Beam) Bolted Connection
I have found a way to set up a bolted connection with an approach that, it is so obvious that It will make some of you laugh as it has made me laugh.
The method is tricky but very simple once understood. I left the file . I think it’s worth and fun.
The bolt is as light as 11 nodes ( Could even be a few less) and uses only beam elements.
The method is suitable for “ready to import”.
The bolt is able to transfer tensile, bending and shear through the shank.
It uses thermal shrinkage for pre-tension. It works with Contact and Bonded contact. (One could potentially check the washer slip failure).
It works with ccx “Static” and Nonlinear. Suitable to bolt shells or solid plates.
It is very fast and robust (convergence in 2 iterations "Static") and could reduce considerably the number of nodes on bolted connections.
Further investigation could find even better ways. I’m looking for a validation example.
Victor : I’m still working on the version with the internal solver. Maybe someone could help with it.
Disla
  • Indeed a surprisingly simple solution. I didn't know bonded contact works all the way out to the circumference of the end of a beam element. Unfortunately, the internal solver only connects them at the node, so it won't contact the edges of the hole. You could make the bolt head from solids or shells but that would take away from the simplicity.
  • edited July 2022
    Hi, Victor,
    The internal solver can set up a bonded contact between a beam and a solid or a beam and a Shell at an intermediate node, the same as we have in this bolt. See file.
    I think the main issue is that pretension, forces to convert the beam element into a Spring, so the whole bolt becomes a mechanism. The internal should find the way to keep the beam as it is (like ccx does) so it can transfer loads perpendicular to its main axis.
  • DISLA, What a nice and simple bolt model!
    I have to try it out.
    Manuel
  • edited July 2022
    Thanks Manuel.
    @Victor, this version has internal solver and all the same elements as the original file but for some reason I can't see, it doesn't work on the full bolt model.
    I fixed the problem why the internal solver didn’t work.
    The projection of the washer’s node need to fall into a surface on the plate. If not, the default Mecway contact is not stablished. That means for the internal solver there can’t be the hole on the plate.
    Attached the 1D bolt solved with the internal solver.
    Contact not so acurate (One point contact)
    Pretension by cooling (No offset of shells is allowed)
    Plates could be Shells or Solid element.
    External forces allowed.
    Linear beam elements only.
  • @disla, is a great modeling trick. The circular beam element in CCX is new? Because as far as I remember all my CCX beams were expanded to hexa elements, not this octagonal prisms. I have checked, and for solid circular section, the expansion is to a octogonal prism element, but for tubes still is an hexa.
  • edited July 2022
    Thanks Sergio.
    I would say it's new. ccx beams where just the rectangular shape isn't it.
    Hallow tube doesn't work to me for this particular model.
