I have found something I can not explain and maybe it might be the response to some convergence issues in the past.
I have run the file from MANUEL MARTIN pasted on Form-finding on tensile structures. (MW-220202-Sail-2.liml)
First run, everything perfect. Nice result.
I was going to save it in my forum files folder but with the Time period /Time Step I'm used to.
As Manuel file achieved convergence using Time Period=100s / Time Step=0.1s I have used Time Period=1s / Time Step=0.001s
Then I have properly updated the g and displacement BC tables to (0s,0m) / (1s,3m) and (0s,0ms-2) (1s,-9.8 ms-2).
I have run it again just to save it with the results and found it fail to converge.
¿Is it not the same?. I thought 1s was ccx Time Period by default and not relevant as a pseudo time for quasistatic.
I’m I doing something wrong. ¿Is it just me?
Since the error message refers to the minimum increment (time step) size, I'd look at that. The default minimum is supposed to scale with time period but maybe Mecway overrode it incorrectly like that other bug you found. Can you show the *STATIC card that Mecway generated?
Another possibility is that it was close to failing anyway and small numerical differences push it in one direction or the other. In that case, it wouldn't really be a bug but a sign to make the model more stable somehow.
You are absolutely right. I had a lot of convergence troubles last week. I almost struggled and drop my nee.
It is odd to me to be forced to consider 100 seconds as a "total time". I wanted to use 1 seconds (of course).
I am aware about under restrained conditions but in this case, all three degrees of freedom are clamped , or at least this is what I think.
This is definitely a large deflection problem with non linear material definition which is 100% non linear but I never imagined to have such a divergence troubles during calculation. I am considering to avoid non linear materials in order to get the form.
I also considered to suggest CALCULIX to code an arc-length method to solve non linear equation systems. Even I am willing to pay for that(only if I can afford it).
About quasi-static analysis, it is almost the same than a dynamic analysis but without accelerations, for that reason the time period of 100seconds make sense. Time matters!!
Thank you for your comments
MANUEL
Thank for you replay.
I do not think that the fabric is about to collapse because in this kind of structures all elements work in tension(zero compression allows==wrinkles ) .Let's see
*WARNING reading *STATIC:
the minimum increment 0.0000000000000000
is smaller then 1.e-6 times the
step time;
the minimum increment is changed
to 9.9999999999999991E-005
which is the minimum of the initial
increment time and 1.e-6 times the step time
** Generated by Mecway 14.0
*STATIC
0.1,100,0,0
For Time Period=1s / Time Step=0.001s
step time;
to 9.9999999999999995E-007
*STATIC
0.001,1,0,0
This morning the original file was unexpectedly failing too.
I have downloaded the file again directly from the forum, run it, and it failed.
I have erased all the previous files related to this example, clean the temporary folder, download the file again and let MECWAY to manage automatically the ccx working directory and then , magically, it converges again.
Possible causes if it helps or could give some idea:
-The graph for the displacement and g force is not updated when I change from 100s to 1s. (See picture). Maybe they are not correctly updated or ccx override to default.
-Maybe there is some common configuration filename from previous runs that is interfering. Ccx generates some files with common names *.nam in the working directory.
-Some values remains in memory and are taken by default.
Meanwhile I will change my default Time Period to 100s just in case.
The graph keeps the maximum time range of the modeler and solution, so it's stuck at 100 s after you solve because the solution has that. This is intentional for consistency when you switch between the two.
Regarding old temporary files. Mecway deletes any existing input (.inp) and output (.frd) file but ignores the others (.nam, etc). I don't think CCX reads any of these so I hope it's OK to leave them behind.
My findings with @mmartin's original model:
CCX 2.17 included with Mecway 14: Stops at 89.33 s
CCX 2.17 compiled with MKL: Stops at 0.0007813 s
CCX 2.19 ccx_static.exe from dhondt.de: Stops at 88.1 s, 0.00039 s, and 100 s on three successive runs. So 2.19 seems to be inconsistent between runs and that's perhaps what you were seeing. It might be caused by PASTIX.
I think the real problem is that the model is a bit unstable. My guess is that failure at the start could be because there is very low bending stiffness against gravity before it's tensioned, so it might not find an initial stable shape. Failure near the end may be wrinkling which could involve some of the snap-through type buckling which CCX can't solve reliably.
[Thank you very much for your help.]
I have being think about it. You are are right, and I am going to mention some important aspects from your comments:
I made up my mind, my approach is wrong and right now, I'm trying out a hand-made-multistep calculation in order to get the minimum constant tension surface. I am absolutely convinced that the form -finding shape can be performed using MW. MW+CCX has it all.
To do that, I am planning to perform an incremental calculation consisting in :
MANUEL
MANUEL
I'm using CCX 2.18 with Pastix and Pardiso and now 2.19 Pastix (default solver).
Ken
You are right but I do not know why.
I realized that as soon as I increased the time period I got better convergence.
In this case, I began calculations imposing 0-1 seconds range but I end up in 0-1000seconds.
MANUEL
imagine; max disp of 1mm ramped linearly to 1 sec., compared to max disp of 1mm ramped linearly to 100sec. the second case is not accelerating as fast. therefore, the force at each time step is less. causing the displacement at each time step to be less. which would make it more likely to converge. at least in reality. not sure if ccx computes inertial loads.
i don't know if that is what you have going on or not. but maybe something to consider.
When I was an Abaqus user, mass scaling by changing density was a trick to make a dynamic run behave in a quasi-static manner.
I posted a model of a ball denting a metal plate in this thread:
https://mecway.com/forum/discussion/comment/5529/#Comment_5529
It is a dynamic analysis with contact and plastic material definition.
