Hi ,
I have a red warning in the contat BC which says contact cannot be used with Nonlinear Dynamic solver.
I have pushed the run button just for fun and it has completed the analysis.
Is it a bug on the warning or may I consider the results wrong? Is it a new feature in ccx v2.19?
I have read in the forum that Nonlinear Dynamics and contact do not work but senns it was only for plastic materials ¿isn’t it?.
I think this should be just a bug in the UI. There is a red colour in the "contact" text for the Dynamic Response and it disappears when I switch to Nonlinear Dynamic Response. Contact seems available for both analyses.
Thanks for the example file, JohnM. Very cool. Seems like you are checking the resistance of some internal component when it falls. I will play some different options later. I don't have any practical experience with dynamics.
I tried adding EXPLICIT to the *DYNAMIC keyword. Calculix didn't complain and ran but produced erroneous results. Ran fine without the EXPLICIT keyword, i.e. implicit solution.
Which version of ccx are you using?. When I try to run it, exits the solver without any message.
Try restarting it a few times. For some reason, it sometimes doesn't run on the first try hitting the run button.
I have tried v.17.1, v.18, v.19 on a WIN10 machine and the one coming with Mecway.
¿Could you post your ccx executable?
I was lucky to press the button but it would be a pity if someone needs it and do not give it a try just for seeing that red alert.
I'm still trying to run the Ball file with Nonlinear and Plasticity and it is not responding to me. I have tried some different versions (maybe a dozen) . ¿What could be the reason Victor.?
Nonlinear dynamics runs more stable with contacts, and I've been able to finish analysis that failed in the previous version. Not sure if Victor changed something , my laptop, Solver, good tips or all together...?¿? Anyway grateful
