Hi, I'm a newbie. I was trying to repeat the Ansys example
to compare the results in Mecway, but unfortunately the test stops at the meshing stage. The attached file is a step generated in Rhino and is a valid solid with no duplicate edges. For me this is a big problem because the analysis of my models starts from solids in step format generated tutti in Rhinoceros V7.
Thank you
Thank you again
mesh
Thank you
If you want to check numbers with the example problem the plate is solid as shown in the video and the piece of pipe probably too but not sure.
I think the values that are making you fail the mesh are the ones related with the minimum per curvature and elements per age.
Try 0.001 each
I would start with big uniform quadratic elements to check that the model runs ok and results. If they are well shaped the results will be ok.
1mm you are going too far. That is more than 2-3M nodes and the problem is probably that you run out of memory.
Remember the video says geometry is the less relevant of the error sources of the model.
Victor numbers look very good to start. I don't see you loose detail. If it works fine you could refine x2.
