Hi, I have the luck that one the part (a compressor cilinder in ductil cast iron) that has been designed and analyzed, will be tested, and we will put some strain gauges, the aim is to check if exist some permanent deformation after test (a simple hidraulic test). What variable should I postprocess (in a lineal or plastic analysis) to select the best place to put the strain gauges?
For gage placement, I would avoid trying to measure at the peak strain location in your model. Place gages a little away from the peak, where the gradients are lower. This will make gage placement less sensitive to positioning error. Once you match your result to test, you can confidently report the "true" peak as what your model shows.
The Strain Energy density can help you to locate the more interesting areas
For an isotropic material the strain energy density function is directly and uniquely related with the principal stretches.
