Is there a way in CCX or internal solver to define a constant, such that it can be used within the load fields in the same way one would enter (50*pi) or (50*e)? Then, to edit in one place versus editing multiple Load vectors is the aim. I commonly have need for 10-20 different constants. If it's a Python script I don't know how to do that at the moment.
With CCX, you can add a *AMPLITUDE block. It's meant for time dependence, but you can just put a single value at any time (eg. 0) and it gets multiplied by all the loads that refer to that with their AMPLITUDE parameter which you also have to add to all the loads.
A simple dirty way could be to enter the common factor in the formula for each load but altered to make it unique, eg. if the factor is 12, enter it as 12.0000000123 or with unique redundant syntax like ((((12)))), then you can open the .liml file with a text editor and search/replace to change all instances.
By the way, some very nice improvements in release 14. Some of my favorites:
