After I select certain nodes, I want to export particular results (e.g., Z displacements) to a spreadsheet. It seems that Mecway's Table allows entire surfaces to be selected but I only want the output from selected nodes.
I have included a model. The image shows a selected row of nodes (frequency mode 6).
Don C.
Thanks, this works. However, I'm having a problem with box selecting the nodes. First I go to XZ-front view, then box-select just the nodes at the upper left corner. This works fine if the mesh was generated without "Fit midside nodes to geometry." However, if I generate the mesh with "Fit midside nodes to geometry" then box-select yields only a single node. In this case I have tried mouse-dragging from right-to-left, left-to-right, top-to-bottom, and bottom-to-top --> always just one node is selected.
(I realize that "Fit midside nodes to geometry" isn't needed for this simple test model. However, I generally use this condition for more complex models.)
