I have this very simple model 123 nodes, trying to connect 1D beam element to a surface of the 2D shell using a model card as per below for distributing couplings, however, nothing is happening. I have named the selected faces which are supposed to be connected to the beam reference nodes.
*COUPLING,CONSTRAINT NAME=BeamCoupling,REF NODE=12,SURFACE=Coupling_faces
*DISTRIBUTING
1,6
CCX 2.23 manual says:
"No kinematic relations are created between the reference node and the coupling surface, so applying displacement constraints in the reference node has no
effect. In fact, the displacements at the reference node remain zero throughout the calculation."
