31 32 is now available at the link below.
https://mecway.com/downloadhttps://mecway.com/download/mecway320.msiChangesAllows multiple custom model definition/step contents/engine input/bulk data for external solvers.
Revolve tool merges on-axis nodes and corrects the shapes of their elements.
Mirror tool with copy has an option to merge nodes on the mirror plane.
Automesh 2D/3D can generate linear elements. The option is also available in the API.
Solution data from external solvers is stored in single precision which reduces file size, memory use, and load/save time.
Solution data with multiple time steps or modes is stored more efficiently in the .liml file.
Strain measures are identified in the outline tree for nonlinear analysis types and in the material stress/strain curve input.
Bug fixesCouldn't open assemblies with Alibre Atom3D. It showed "License key is not found or expired or invalid for attempted operation".
Bug 47. Accounts for a change in the OpenRadioss solution beam moment definition according to the release version number which you specify. It also shows warnings on beam moments which are incorrect with some versions of OpenRadioss.
Split step assembly failed with GEOMETRICALLY_BOUNDED_WIREFRAME_SHAPE_REPRESENTATION.
If the solution contained global values (internal energy, kinetic energy, or time step) but no node or element values, then none of it was saved to the .liml file.
I see that you did multiple things to reduce the file size and I am very grateful for that as the file sizes for the OpenRadioss crashbox simulations I did before christmas was huge and it gave me issues when opening the files.
The file size improvement can be obtained for existing files by opening them and saving them again. In one case, the file size reduced from 12,7 Gb to 9,8 Gb, so while it is still a large file, a 23% size reduction is very nice! I have lots of other files from iteratively developing those crashboxes that are around 20 Gb and a few that are as large as 32 Gb, so now I just have to open them and save them again to release about 100 Gb of space. It might be ok for me to outright delete some of the iterations though...
Also thanks for the multiple custom model definitions/engine input and so on. For those who doesn't follow the github page where we can request improvements to Mecway, the benefit of this is to be able to make custom contacts, timestep size control and so on and be able to suppress them easily it as they are separate features in the feature tree.
If it halves the file size, then that's a massive saving.
I am very happy with these smaller file sizes
I haven't timed the time to open the files but I can say that they do open much quicker as well.
Error. Please save your work in a different file, close Mecway and report this to support@mecway.com
The given key was not present in the dictionary.
Version 31
System.Collections.Generic.KeyNotFoundException
System.ThrowHelper.ThrowKeyNotFoundException
System.Collections.Generic.Dictionary`2.get_Item
SelectionPropertyCollection.ManagerTreeNodes
ModelData.ManagerTreeNodes
ProjectClass.ManagerTreeNodes
ViewPort.RefreshAll
frmMain.pnlRender_Layout
Control.OnLayout
Control.PerformLayout
ScrollableControl.OnVisibleChanged
Control.OnParentVisibleChanged
It may have nothing to do with the new version but I was able to get back into the program with an old version and the new version does not appear to want to open it again. I was in the middle on making some loads a constraingts and was trying to make a new group - it was a big file with 300,000 or so elements so that may also have something to do with it
The bug is new fixed in version 32 which is available here https://mecway.com/download/mecway320.msi and that will eventually become the next published version if no other new bugs are found.
Sorry for the trouble.
EDITED: I have meshed with coincidents nodes bolts and base, so some of the faces that define the pretension force was shared between two components. Once I remove those shared faces from the selection, the visual representation is ok.
Best regards
