Hi everyone, is there a trick to hint if the axial force value is compression? in some example of mine I'm wondering if a negative axial force on beam value means compression maybe I am fooling myself.
Yes, negative axial force means compressive stress as the neutral axis. Although, if there's thermal loading, the element might be lengthened (tensile strain) while having compressive force/stress.
