Failure criteria activation
Could someone help explain how is possible to get the von Mises failure criteria activated?
I tried a CCX nonlinear study with plastic material and I cannot select any failure criteria, per image attached.
  • It's not available for CCX, sorry. However, all it does is show the factor of safety in the solution. You can make that by hand using a formula, or get von Mises stress by adding it to the solution, or yield stress for plasticity by defining a plastic material type.
  • Thank you.
