I'm finding more use for membrane elements and recently I have been getting some success in using them in the belts running around sheaves. I have seen mention of potential bugs in Calculix with these elements, can any one point me to where I could find more info about these bugs? I have noticed some odd differences in MW output when using membrane elements. I imagine that in calculix, membrane elements are expanded into solids like shell elements are. However the output from MW makes me question this. I attached a simple test that, I hope, illustrates
my point. In the case of the membrane results, the output shows only a 2d film, not a 50mm thick sheet as in the shell analysis. (also I see the shell bending more smoothly than the membrane). My other observation is that generally the membrane analysis takes longer. My questions are - have I set up the membrane elements correctly? and if so is the representation in MW suggesting that membrane elements remain 2d in the analysis?
To see the expansion add NODE FILE OUTPUT 3D option
