I have been experimenting a little with membrane elements on a simple pillow (with a longer term plan to use them to model sails). To use M3D8 elements I had to omit the shell key card add a new *MEMBRANE CARD and introduce a custom card for the M3D8 elements. Is this the best approach, and have I missed anything? When the model uses membrane elements the max deflection is some 50% greater - this sounds reasonable to me but do others feel this is likely??
You can use CCX -> custom element type to change quad8 to M3D8 so you don't have to rewrite all the element definitions.
