Good afternoon to everyone:
Your help would be greatly appreciated. I am currently calculating a steel joint using 6 bolts.
I am performing a nonlinear analysis since I am using contact, tie bonds, and nonlinear material (steel).
As soon as the calculation was complete, some spiky elements appeared around the bolt holes
Do you know why this happens?
thank you
Manuel Martín, from Spain.
I would say there is some initial mesh penetration or too much clearance in the contact areas. If "Adjust" is active the nodes are projected strain free from slave to master. Those crazy nodes flying could be those adjusted nodes.
Moving direction gives you information about where they come from and where there is penetration or too much clearance.
As Sergio says doesn't seem too much but I think you could improve projecting the nodes to a cylinder shape on the holes area.
Thank you for your help I really appreciate it.
DISLA: I will remesh the bolts in order to improve the smoothness of the stem. Great 3d view of the bolt-hole connection.
SERGIO: Your are right. The displacement is under 1mm which is fine also for me.
VICTOR: I cannot activate "Fit midside nodes to geometry" because malformed elements appeared (negative jacobian). So, I had to disable this option(what a pitty). Do you know any workaround? I will change the mesher(I like to using gmsh, so I will switch to tetgen)
Thank you to eveyone.
Manuel
You all are right.
I sort it out.
I turned "Fit midside nodes to geometry" ON.
I remeshed the stem of the bolts
and it works now!!!
Thank you very much(again).
Manuel
Stresses decreased compared to the previous and broken model.
Thank you all .
Manuel
I would be very interested in validating or at least end up as close as possible to the Bearing capacity provided by EUROCODE 3.
I’m posting the EC3 result for this configuration.
I have changed the bolts to 8.8 as I don’t have 6.8.
I’m also posting the basic geometry as clean as possible I'm working with.
I would invite anyone interested to comment or provide suggestion to see if we can get as close as possible to the EC3 results with MECWAY/Calculix.
-Some point under consideration:
-Element type. (I’m using C3D8I)
-Stress Strain curves. (Bilinear with E/100 as tangent modulus)(* Victor)
-Mesh density for the different elements. (First trial 28.000 Elements)
-Pre-tension procedure (I’m using Fn= 70% * F u,b * Section Resistant )
-BC. (One end fixed , multiple contacts and Rigid body to apply load on the other end.)
(*) Note: Victor, I’m looking at the inp and I can see that the Bilinear Plasticity is written like:
*MATERIAL,NAME=S275_Beam
*ELASTIC,TYPE=ISOTROPIC
210000000000,0.3
*DENSITY
7850
*PLASTIC,HARDENING=ISOTROPIC
265000000,0
2100265000000,1000
I think that should be (2100Mpa+265Mpa)*1.000.000=2.365.000.000Pa
265000000,0
2.365.000.000,1
I see what happens. Seems like you take the second point of the line at a strain of 1.000 . Strain rarely should go beyond 0.3 (30%). As reference, EN code considers an allowable plastic strain of 0.05 (5%). I think using 1.000 could be causing some strange response.
I really like the way you use MW-groups and the new MW bolt pretension option which I am going to use from now.
I agree with you that we should go on investigating how to retreive moment-rotation plots of the joint. T I think we have to monitor some control point throughout time and plot the values previos some trigonometric calculations.
Anyway, I saw your DISLA-Bolt-model using frames; nice and smart.
And, good weekend to every one.
Manuel (mmartin)
Another thing I consider interesting to look at is the meshing. Look at the gmsh algorithm. I like to benefit from the high quality of it's surface mesh and then extrude. Beams are very suitable for doing that.
I have a lot of theory about connections checking procedures but none of them shows where/how to apply the loads. Force and moments usually come from a beam model and the node forces needs to be transfer to a finite 3D model. ¿How long should we consider the beam members to consider the submodel a good representation?
I can see you apply forces directly to the plate but that's not what is done in other software.
¿Does anyone knows or has some reference / guidance about this point?
https://mecway.com/forum/discussion/comment/5412/#Comment_5412
I also have another question about grouping contact surfaces, are there any likely issues if a group of master and slave surfaces are put in one contact definition- in the pic attached I have collected all the underside of the washers together (on both sides of the beam) and made a contact definition with both top and bottom faces. The alternative is to make up many defintions for each washer face contact (pretty time consuming but perhaps necessary in some occasions??)
Yes, you can have many surfaces in the same contact definition. Just be careful that the wrong ones don't connect together - for instance, a plate with master and slave on opposite sides and nothing else in the same contact definition nearby can connect the two sides of the same plate to each other.
Are you aiming to model the case where the plates slip and the bolts are in shear, or where they only provide tension? That might determine whether the washer can be bonded to the plate or not.
