Mecway 26 is now available at the link below and includes the Spanish language manual translated by Germán Bresciano.
https://mecway.com/downloadChanges:
GUITape measure and node info box update with changes to time or field variable.
Unit dropdown in node info box is below the coordinates, which it applies to, instead of at the bottom of the box.
Zooming on timeline graph using mouse wheel or left-drag and context menu item “Reset zoom”.
Grid lines on timeline graph. Turn on/off with context menu.
Low importance error messages displayed as warnings in orange instead of red.
Material properties windows opens on the first tab with a valid material type.
Loads and constraints applied to geometry surfaces without a mesh no longer show an error message.
Text input areas for CCX custom model definition and custom step contents use a monospaced font.
Internal solverIncompatible hex8 elements for all 3D mechanical analysis types with both solvers. Generally superior to standard hex8. Enabled by default for new models.
Dependent/slave DOFs of MPCs can appear as independent/master DOFs of other MPCs. This allows you to chain Node-surface couplings or bonded contacts together and put constraints on bonded contact master nodes.
Improved convergence test for compression-only support.
Distributed loads on beams generate moments as well as forces.
Faster solving for tension-only elements.
Convergence graph for Static 3D shows number of changed contacts instead of number of closed contacts, and shows displacement error.
Doesn't solve if an element orientation is defined incorrectly.
CCX solverNo longer generates contact state by default because it can create a big slow .cel file.
Custom CCX material input in material properties.
For Custom step contents, removed the deprecated option to insert it before *NODE FILE.
Deprecated "End time" for "Regular time points" in Analysis settings. The default (0) now means end time = time period.
Basic support for 3rd party open source explicit dynamics solver OpenRadioss. I'll make another post with more details.
Bug fixesBug 44
Various minor bugs
1. Install new version and leave old version(s) installed?
2. Install new version and remove old version(s)?
3. Remove old version(s) and install new version?
I've noticed that new versions don't seem to mind coexisting with previous versions.
Ken
You can copy 25 to somewhere else before installing 26.
Where can I find the shape functions of this formulation?
Three-Dimensional Static and Dynamic Analysis of Structures A Physical Approach With Emphasis on Earthquake Engineering, 3rd edition, by Edward L. Wilson, Chapter 6. Incompatible elements.
