The mesh tool in Mecway is very versatile and easy to use. But I am wondering if there is any other 3rd party mesh tool (free or inexpensive) that can make shell meshing easier? I am only interested in the shell elements. For example, in ANSYS workbench, I can model any surface body (with proper connections between components) and then import the geometry into Mechanical where I can get the shell meshing instantly. Any mesh tool can achieve the same effect and can be directly imported to Mecway? Thankyou.
On the comercial (from expensive to very expensive) side you can use any preprocessor that can output the mesh in Abaqus inp format, such as Abaqus CAE, Siemens NX, ANSA, Hypermesh, Femap, Cubit
- Midsurface in DesignSpark Mechanical. This is a very cheap, white-labelled ANSYS Spaceclaim, which is an extremely capable direct modeller so you get all the CAD kernel horsepower for a fraction of the cost. Whilst you don't get a midsurface tool in the whitelabelled version, it's about 4 clicks to get the same result using the direct modelling tools. You can also defeature and repair faster and more robustly than NX, CATIA, Solidworks, you name it.
- Export as high-res STL. This gets around all the tangency BREP problems influencing your mesh edges that you get using STEP or IGES, it just gives you a reasonable fidelity initial mesh native out of the CAD tool. Want more fidelity? Set the facet settings smaller.
- Use Coreform Cubit Learn licence (unless you're doing commercial stuff, in which case you need to pay), import the STL, use their excellent quad meshing tools and export as an Abaqus INP format - this seems to be the happiest import to Mecway.
If Calculix, beware the C3D20 brick limitations.
