I Victor, Maybe for the next version it can be included the possibility to manage modal -spectral analysis. It could be very usefull for steelworks frame earthquake analysis in accordance with the Eurocode 8 standard.
Another help would be to be able to import a step file with multiple bodies (assembly) and have each of those bodies created in the Mecway design tree. As it is I have to import many individual files each with only one body.
The next version (25) will probably have support for Alibre Design/Atom3D assemblies where each part becomes a separate component in Mecway. Not for general STEP files but I hope to find a way to achieve that because assemblies are quite important.
Victor, you should put the link to Github somewere visible in the frum or website because whern we have a feature suggestion we don't remember the Github link.
Honestly, I'm not a fan of github and don't want to create an account there just to suggest stuff. It would be better to do it some other way, in my opinion. A way that doesn't require us to create more accounts.
Hi every one, I've finally launched my first dynamic response analysis with a seismic spectra (T(s) vs Acceleration (ms-²)). I have some trouble with beam release which it's not allowed with this kind of analysis but why is it not possible (maybe go back to constraint equation)? Maybe for the next version of MW.
Another thing that could be better is having the possibility to extract maximum value of the outputs (beam forces and moment sorted by nodes). The outputs is allowable by time step which it's normal the idea is too output maximum value by nodes in the .csv file.
One last thing is to have the possibility to disable some of the columns in my exemple I don't want to have the time step and the time in my csv file.
Mecway has had the capability to do composite layups for quite some time.
+1 to this!
That's an embarrassing mistake with the more info label!
Regards.
