Hello everyone,
I discovered Mecway some weeks ago, and I have found it wonderful. I had also used Lisa (too simple) and Salome (too complex), and it seems that Mecway is just the right size
However, I have a problem that I cannot simulate: I have a frame in 3D built from beams (line2), and I would like to simulate some of the beams as supported (that is, the can rotate at its ends). I know that I can check "truss" from "element properties", but this does not work if the beam is made of several elements (because intermediate nodes don't rotate). Please, see the attachment to make it clear.
I think this might be easily done somehow, as the solution of an element hinged-fixed is known and can be inserted in the rigidity matrix. So, is there a way to simulate this? What have I missed?
Thanks!
edit; updated the attachment
i had to laugh at the results. it's the size of a twin bed but it's saying it can hold 5 m1 abrams tanks.
Hi and welcome,
To allow the rotation on a beam you could also proceed as this:
Activate the thickness of the beam to see its shape.
Select its surface on the extreme like in the picture.
Apply to that surface a flexible joint on beam Boundary condition.
If you only want to allow rotations on a specific plane check on the manual the axis convention on beams.
The attached file shows some different configurations of a portal frame.
If you want more detail on the trusses you can convert it to a regular beam and allow rotation on its extremes the same way as described above. Notice that non symmetrical sections do not model bending twisting coupling.
and one end hinged and other fixed:
So, the flexible joint was exactly what I was looking for, and I admit that I have never found it on my own (it is a bit tricky how to set it up).
So, I made a simple simulation, to check it with the analytical solution, and it worked like a charm! There were two frames, with and without flexible joints, at the front, vertical beams are not deformed because there is no moment transmitted by the upper beam, due to the flexible joint:
If you are getting the right analytical values maybe it is just a visual effect.
the pic, below, shows the pin orientation:
the pic, below, shows what the model looks like:
below shows more pins added:
below shows different leg orientation:
However, the numerical results seem to be equivalent regardless of which face is chosen for the pin.
Selecting both faces for pins seemed to default to the single face case.
When the column is pinned, the beam and node rotate together.
When the beam is pinned, the node remains unrotated with the column.
When both are pinned, the node's rotation isn't part of the system and seems to remain zero in this case but it might be at risk of rigid body rotation.
