Hi Victor,
I use Mecway to study truss structures (static analysis mainly), with a particular interest on the joints. I post-process the results given by Mecway (N, V, M of beams) and could not do the same with ccx results.
There is a tension-only material for bar elements in mecway, but no compression-only material. Do you plan to add it to Mecway (internal solver) in a foreseeable future ? Or is there a reason why it is not implemented ? Or a "trick" to transform tension-only truss elements to compression-only elements ?
You can arrange beams to connect to the opposite ends of the tension-only member though it's a bit fiddly. Here's an example that also uses an artificial beam with extreme section properties to couple rotations while releasing longitudinal displacement.
I think another way would be to couple your structure to the opposite ends of the tension-only element using constraint equations.
So could compression only elements be added in a future version of Mecway ?
I cannot think of a way to make your present solution to work for me (compression only via tension only elements), but maybe I did not understood it fully. Here is an example of a simple structure.
My goal (in this example) is to have the diagonal elements to behave in compression only. I use short bar elements to control the stiffness of the connections, and also to retrieve the forces at the connections (for postprocessing). On the left there is the full structure. On the right there is the structure in which I removed the diagonal element in tension.
If I could double the connection bar elements, one with elastic behaviour and A~0, and the other with compression only behaviour, I would get more or less what I am aiming for. Am I missing something ? Is there a way to make it work with tension only elements ?
Not sure if this possible as I have not used contact that much on Mecway.
Would it be possible to apply contact at the joints of the truss members, this will allow for only compression to transfer. I have done a similar thing on Strand7 when checking how the loads will redistribute on conveyors when a leg lifts of the ground during high wind loads.
Thank you for your answer, but it does not apply to this case use.
The spacing between the two middle nodes would lead to error in the compression stiffness, so move them as close together as needed.
The deformed view shows it opening up like a Z-shape but I'm not sure if that's something wrong or an artifact of the scaling. The displacement of everything else isn't quite the same as the structure on the right and I'm not sure why.
I'm not sure about having compression-only truss elements in the next version.
Thank you for your example, it is what I was hoping for.
