I was unable to locate where or how Mecway can apply a ramp force. Could someone help me locate this function or assist in any way to express it in the software. I have attached a simple sketch as a visual aid. I have posted a possible problem such as a steel plate lying on the ground. For argument sake lets take a 50mm plate, 2m wide and 9m long with a maximum ramp force of 981kN applied over 6m. Can we enter an equation with gradient for a ramp force?
While there isn't an equation input for this, you can achieve it using the hydrostatic pressure load. That applies a trapezoidal force but you have to work backwards to calculate the parameters. For example:
Maximum linear pressure = 981kN/m (I assume 981k is the maximum force per length, not total force).
Maximum pressure = 981kN/m / 2m = 490.5 kPa
Find the fluid density that would have this pressure at a depth of 6m:
P = density * g * h
490.5kPa = density * 9.81m/s^2 * 6m
density = 8333 kg/m^3
So you can use this density value, along with gravity with x component = -9.81m/s^2 for the hydrostatic pressure load in Mecway.
This method starts to get a bit impractical when you actually want to use gravity for the structure too, or when there are multiple ramp loads in different directions. In those cases you might need to use a sequence of uniform loads to approximate it.
Ramp loads are absolutly "must be". I am working as naval architect and we have many cases where many different pressures are appled to different plates (other one ad ship side, oter one are at internal tanks, different as wind at deck equipment etc.) in one model in the same time. There are cant be modelled as "hydrostatcic pressure" defined as is in MW... Pls consider it in next release
Please don't do a Microsoft style ribbon GUI, I can't stand those. They take up more display space and make it take more clicks to do things.
Mecway does look dated and the menu-and-toolbar UI came at a time when most people had smaller screens. By making use of more screen space, I think it can be made easier to find things whether that's with a ribbon, MoI style "toolbars", just putting labels under the icons or something else.
yes i realize mecway looks dated. but for that matter so is the website. so if you are worried about people not giving mecway a try based on looks alone, then the website would be a logical first step. i hope fea users are smart enough to realize looks alone don't mean much. but i am all for a refreshed gui.
the ribbon gui i am thinking of is the standard microsoft ribbon. it is just huge. you usually have to minize it and maximize it to get it out of the way, so right off extra clicks. then you are left hunting for what tab a given icon is on, more clicks. etc... basically they are just too darn big and add extra clicks. i don't see the need to lable groups and put groups on tabs etc... toolbars are already naturally grouped so naming them and putting them on tabs adds no value at all. ansys and other fea programs sometimes only have toolbars show up when they can be used. that is a much better way to go in my opinion. i also like bigger clear icons with text. so it is easy to find the icon you want. this is something the moi gui does very well. you can download a free copy to see the gui. but in moi i would say the icons are probably too big if anything. a lot of users really enjoy customizing a gui. they like to be able to add and remove icons and toolbars change colors and so forth. so if you were trying to please the most people i think a gui that can be customized would be good. lastly a multi platform software package is always asked for. people like to be able to use linux, apple, and microsoft. so strictly using a microsoft gui kills any cross platform compatibilty. i love mecway and your development efforts. sorry if i was too harsh about this one issue. but i just really think a microsoft ribbon, even if spruced up, would be a horrible decision. i mean how much can you polish a turd?
As to being locked into MS. That's unfortunately already the case because Mecway depends on winforms and Direct3D which are not available on other platforms, besides VMs and emulation (Wine). I'd love to be able to port it to other OSs without too much rewriting but this is, well, vendor lock-in
As professionals, we expect tools to do their job. From what I see from the trial license: could the interface look better? Sure. But that doesn't say much about how it's designed. Craiglist is still arguably an extremely well designed site but looks like 1998.
Just my 2 cents
