Use of IA-FEMESH in Mecway
Hi there
I was wondering whether we can import "IA-FEMESH" generated mesh into mecway?
Best regards
Aftab
  • I am pretty sure you can export from IA-FEMESH to ABAQUS format. This is nearly identical to CalculiX format, and you can import this directly. It's possible you'll need to make minor modifications to *SOLID SECTION command, but I would just try importing, you might get lucky.
  • Many thanks John. I will give it a try.
