Hello. I am trying to heat the inner surface of a tube from a rod radiating heat (it can be thought as a black body at 800 C). I understand that CCX can run this heat transfer in the steady state mode, but I when I add the radiation constraint I get a message saying the CCX mode does not be used in this solver.
Can somebody provide any advice?
Or you can use transient and very small values for specific heat capacity and density so it only ends up doing one or two time steps.
It is in principle I just need to see what is the temperature map of the enclosure surrounding a constant temperature hot "rod".
Any advice? Thank you.
However, this will only work in the same way that it does with the internal solver. To get radiation between surfaces, you'd have to modify the CCX input manually. You might be able to do that through CCX -> custom model definition and custom step contents but I'm not sure about how to set it up.
Radiation doesn't seem to work reliably with steady state with CCX. It might be something to do with the default time step size that Mecway sets or the load ramping the CCX does. Or it might just be that the examples I tried were too extreme.
When I take your simple example and switch it to CCX steady state, it does not like the radiation.
When I take my current model and switch to CCX transient, the radiation remains unchallenged. The model won't solve because I need to scale to increase the size of tiny elements. It goes through the motion of solving using internal transient, but comes up with nonsense, probably because I failed to enter density and specific heat properties. I'll have a tinker and see if I can get it to run sensibly.
Using transient could be a clunky and slow workaround, if need be.
With my present model, radiation is insignificant and could be turned off, but I want to leave it for now as the model is running too cool so I need to drive up the temperatures a bit. Hopefully radiation will remain insignificant and I'll chuck it.
