Modal Analysis
Which algorithm does Mecway uses for 3D Modal Analysis, like Lanczos we uses in Ansys
  • The internal solver uses either of two eigenvalue solvers depending on the size of the model:
    500 DOFs or more: ARPACK's Implicitly Restarted Arnoldi Method which is similar to Lanczos since the matrices are symmetric (except for cyclic symmetry where there are Hermitian).
    Less than 500 DOFs: LAPACK's dspgvx. I don't know what algorithm that uses but it's more efficient for small problems or large numbers of modes.
    I believe the CCX solver uses ARPACK.
  • Thank you for the information
