I have modeled a fan base structure and am looking for the modal vibration frequencies of the structure. The structure is fabricated from c-channel and plate. I am running into an issue where the majority of the modes found are localized resonances in the structural shapes. e.g. localized twisting of the c-channel. Is there a method to only look for significant mode shapes? More interesting in looking for bending/twisting modes for the entire structure, etc. Not sure if there is a way to change a setting that would influence the results or not.
Thanks.
If you read the file *.dat you will find extra information about the mass participation for each degree of freedom and vibrational mode.
The higher value (related to the dof) for each mode shapes will tell you about the bias of the structural shape (twist/bending...).
mmartin
Then to do it the "dumb" way, increase the number of modes until you can find the ones you want.
If you write the *FREQUENCY card yourself, you can specify a minimum frequency. That still finds all the modes below that but then discards them, so it probably isn't any faster to solve but might keep the solution size down if that's a problem.
Configure MW to place the ccx temp files into the same MW working directory.
Doing that , you will see the *.dat file along your MW project.
Just open it with your favourite ASCII editor,
